Wiring a 120 Volt Mulitplus off-grid to 240 wired mobile home.
learaviator
Registered Users Posts: 12 ✭✭
My home is currently being powered by a Magnum MS4024PAE, 120/240 volt inverter charger. I am switching everything over to Victron equipment, this Multiplus II install is the last piece.
Nothing in the house is 240 volt, Everything is 120 volt. I am powering both line 1 and line 2 with the Magnum inverter.
I turned every possible thing on in the house at the same time and total system draw is 38 amps. Line 1 draw is 20 amps and line 2 draw is 18 amps so both legs are fairly well balanced.
I bought a Victron Multiplus II, 120 volt, 5000 va inverter as I was told I really only needed the Quattro if I was hooking up to the grid. I was also told I can just hook a jumper between Line 1 and Line 2 and run this Multiplus II 120-volt inverter this way.
Any thoughts on this? Also, I would like to keep the whole Magnum system as a backup, but trying to draw a schematic and figure devices needed is a later project.
Thoughts on tying line 1 and line 2 together by using the Multiplus?
Thank You!
Thank You!
I'm not sure if that's okay with the Electrical code but jumper between line one And Line 2 is the way to do it i probably use 8 or even six gauge wire
Thank You!This is done quit often. Just use the correct wire size and corresponding breaker size to protect the wire. Any jumpered panel I worked on I labeled or wrote on the panel schedule "120 volts single phase only".When someone follows the work and sees a single pole breaker as the main, they will realize there is a single conductor feeding the panel and know that there is no 240 volt split phase available.
As said, label it to make it clear. If there is existing insurance, they probably do not care as long as the area looks safe and normal. Make sure the breaker/wire gage that Victron recommends is used. The main breakers can just be a disconnect if they are larger. Again, labels!"we go where power lines don't" Sierra Nevada mountain area
- 228 Forum & Website
- 653 Solar Water Pumping
- 619 Discussion Forums/Café
