need help with multi unit config on 2 xw pros
cha09
Registered Users Posts: 2 ✭
hello everyone, i need some help here, i have the xw pro using for quite some time now, works flawlessly, recently got another as they where on clearance sale, now im trying to setup the second one so ill be able to run more loads, heater etc, i have upgraded both inverters to the latest firmware using the insight home, i have done the connection for the xanbus and sync ports using cat5 ethernet cables, ive put the inverters in standby mode and set the original (one i had working) to split phase primary, ive set the device number to 1, and xanbus port to 2, on the second inverter i put it in standby mode and set it to split phase secondary, set the device id to 2 and xanbus port to 2, when i switch both inverters to operaton mode, the secondary transformer becomes noisy (loud humming) and the screen shows 15kw to 17kw and there is no voltage output, could someone guide me as to what settings are needed so i can get the second one working, thanks
I have no direct experience with Schneider XW inverters, but have looked at some of David Poz's YT vids ?:
https://www.youtube.com/watch?v=7zXcny77sKQ&list=PLVe7nJBrjHRcKkAhwssMi25jU0SC4m0Z1
Also the DIY Solar Power Forum has quite a lot of traffic on these XW inverters:
https://diysolarforum.com/search/3660538/?q=XW+6848+Pro&o=relevance
I have no affiliation with either of these entities, Just a member on the DIY Forum.
Good Luck, Vic
Found the Poz youtube, where he adds a second XW inverter, and explains quite a lot about the setup:
https://www.youtube.com/watch?v=mskvgkIl2kM&t=51s
I am late to this discussion, etc, but Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
hey guys, thanks a lot for these vids, helped me understand a bunch of stuff which i didnt, i now have both inverters in primaty and secondary, i no longer get the error F66 or F69, what i have now is the secondary trying to trip in but wont come up, i end up having an error that says failed to sync, see below
can someone help me understand how to fix this, i think there are some settings that need to be tinkered with, i'm using firmware 2.04 bn0049, also i understand i need to set grid codes, but it asks for a password which i have no idea what it is, is there some type of default password?, thanks
The vids should have info in them on the commissioning guide.
https://solar.se.com/us/en/xw-pro-commissioning-guide/
You will be prompted to email for the pass-word."we go where power lines don't" Sierra Nevada mountain area
cha09,
Do you have a patch cord connecting the AC Sync ports on the inverters? It should just be one cable running from the first inverter to the second. Do not use any terminators and don't mix up the ports with the xanbus ports. -
Please read this Thread on the DIY Forum:cha09 said:hey guys, thanks a lot for these vids, helped me understand a bunch of stuff which i didnt, i now have both inverters in primaty and secondary, i no longer get the error F66 or F69, what i have now is the secondary trying to trip in but wont come up, i end up having an error that says failed to sync, see below
https://diysolarforum.com/threads/schneider-xw-pro-configuration-settings-for-a-new-system-multi-unit-install
EDIT: when I tested the above Link, it failed. You might try the following part of the Link, entered in the DIY Forum Seardh box. You might need to join that forum as a member, to do searches, 'Schneider XW Pro Configuration Settings for a new system multi-unit install '
OR, Just the ' XWproGridCodes ' as a search term on that forum ...<
EDIT: The above does make a reference to this code, ' XWproGridCodes ', but one needs to be very careful, when proceeding ..
This is well above my pay-grade. Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
