Solar Tool Battery Charger
justme
Registered Users Posts: 1 ✭
1. I have a bunch of 18 Volt Ridgid tool batteries, I want to charge by Solar. Will an MPPT charger convert higher voltage panels to the battery's voltage?
2, I have a 260 amp Leece Nevill Alternator. Any suggestions on how to drive it with 5 mph and up available winds?
Some MPPT's will do this but if I were you I would just get a small inverter, small battery, MPPT solar, and use Rigids AC tool battery charger. Less chance of damage and voiding Rigid battery warranty."we go where power lines don't" Sierra Nevada mountain area
I could not find any DC versions of the Ridgid chargers... For example, last I looked, Makita had 12 VDC input chargers to plug into a cigarette lighter socket.
As Dave says, your best bet is to start with a 120 VAC inverter+XX Volt battery+solar+MPPT controller sized to the charger input power (Watts), and how much charging per day (Watt*Hours) to size the battery bank and solar array.
Ridgid appears to have a handful of different chargers available (low, med, high power) and 1/2/6 port chargers--So you need to design the system for the chargers and number of charging stations you wish to support.
Use a Kill-a-Watt type meter to measure the "peak" Wattage, and how much energy (Watt*Hours) your need, then design (on paper first) your solar system to support those loads.
https://www.amazon.com/kill-a-watt/s?k=kill-a-watt
Make sure your AC inverter is a True/Pure Sine Wave type (TSW/PSW) and not a Modified Sine Wave type (MSW)--As MSW wave forms have been known to work incorrectly or sometimes damage tool battery chargers (and other equipment).
While it may be possible to make a DC connection to Ridgid batteries, as Dave says, the chances of damaging the expensive batteries (or even causing smoke/fire in some cases) usually are not worth the risk.
