is there a gfdi fuse on a sma sb3000 ?
tampasolar
tampasolar Registered Users Posts: 90 ✭✭
This is a 2014 unit.  I cannot find any such fuses.  Any help would be great.
Can I post any photos in this forum ?
hybrid: two xw6848 pro with five mppt60, 13 kw pv
17 cell Eve 280ah LiFePO4 storage  14 kw (now at 3 banks) total 40 kw
gridtie: sunny boy sma 2x 5k
Gateway / Insight Local
    Dave Angelini Solar Expert Posts: 7,127 ✭✭✭✭✭✭
    On the larger SMA, I have been paid to replace a module under warranty for failure to start from Arc/ground fault. It is often the solar that is the source but also just as much chance the AFI/ GFCI components. No fuse BTW. Looks a bit like the lower right of the pix from long ago memory.
    Check the SMA site also.
