Outback forum
706jim
Solar Expert Posts: 529 ✭✭✭✭
It appears that it no longer exists. Does anyone have the inside scoop on this?
Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
I do not visit Outback very often... This is the link/site I found and it does work:
https://forum.outbackpower.com/
https://outbackpower.com/
Outback was sold sometime around May(?) 2024--And there was a lot of confusion as things got straightened out:
https://forum.outbackpower.com/viewtopic.php?t=18797
https://forum.outbackpower.com/viewtopic.php?t=18711&sid=f740daa68164d47c4912551787daa98f
I've never had any problem with loading the Outback forum.Their tech support has been posting on the forum and they have been updating their webpage from time to time.Edit: I have been visiting the Outback forum daily for the last two years.
got it working again, just had to change the URLIsland cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
