Where are the 48 volt brushless units found
t12zh
Solar Expert Posts: 62 ✭✭✭✭
i want to buy just the unit itself (48Volt).
I want to buy one now.
I am going to build a large Vertical unit.
Where can i find a newer brushless unit.
Greg
Greg
Re: Where are the 48 volt brushless units found
same place the good performing low wind units are to be found :roll: -
You might get a useful response to this and other wind-related questions at:
www.otherpower.com
http://www.otherpower.com/otherpower_wind_alternators.html
Mike -
Pehaps this Google search string will help:
http://www.google.com/search?hl=en&q=wind+brushless+generator+48&btnG=Search
HTH,
Jim / crewzer -
You also might try salvaging normal automotive/truck brushed alternators for your first testing... The brushes should last 5-10,000 hours pretty easily (as they are slip-rings and not commutators).
That should be worth several years of operations/experimentations until you get the rest of the system right--before you spend big bucks on a brushless unit.
I have a friend that knows i am on this wind power quest and found a man that sold me a air 403 (i think) Should do 12 24 36 or 48.
So i bought it today for 100.00 with new blades that i needed anyway.
I am going to see if i can repair it.
Greg
I am going to start a new thread on it.
