Wattsun positioner failure
geoffleach1
Registered Users Posts: 1 ✭
I have a Wattsun (Array technologies) AZ100 dual-axis tracker. For ~30 years its performed flawlessly. Until now. One of the positioner moves in only one direction,
I've tested with direct power, so its not the exterior wiring.
There's no attempt at all to move the panels. Nothing to suggests its trying.
The positioner is a Thomson Saginaw Performance Pak 7822344
I would appreciate suggestions on how to proceed - what should I be looking for?
Try contacting Jeff or his son Kyle. They bought the consumer part of Array Technologies.Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 650ah LiFeP04 battery bank - 5 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
