EQ new batteries
gicamuci
Registered Users Posts: 42 ✭✭
So I have a new set of batteries coming in.
Is it a good idea (or bad) to perform an initial equalization ?
6.2kW, 12 × 250W + 4 x 275W + 4 x 285W + 3 x 330W (driving the pool pump MPPT controller or charging batteries on cloudy days) solar panels , FM80 MPPT CC, WavePower 6kW pure sine inverter, 16 x Dyno D90 in 8s2p strings 420Ah @ 48V battery bank.
Champion Dual Fuel 7.2KW gasoline/6.5KW propane gen for emergencies only.
Lead acid, not needed. Just fully charge them all individually before you assemble your bank
