What's a good LifePo4 charger?
nschizzano
Registered Users Posts: 38 ✭✭
Hi what is a good LifePo4 charger? It For 1 200ah litime lifpo4 battery. I want to charge it fast from the gasoline generator when needed.
12v by the way
Is this one crazy?
RecPro RV Converter 125 Amp | RV Power Converter & Battery Charger | 4 Stage Smart Charging | 120VAC to 12VDC | 13V to 16.5V Operating Range https://a.co/d/8dYMiFK
I have a small 12v LiTime battery and purchased the small charger for it. A quick look shows LiTime makes an 80A charger as well. I would investigate the charger and its power requirements to run from the gasoline generator you mentioned.
4-Risen 320 watt in series/parallel, 8-215ah 6 volt GC2 batteries in series, Exeltech 1100 watt/48 volt inverter, Tristar 45 MPPT controller. -
Oh wow litime has an 80 amp. Awsome. I wonder the noise of that one. I can ask them the speed of charge and harm it would do to a 12v 200ah lifepo4
- 234 Forum & Website
