48VDC LiFePO4 bank with TS45 and Victron 375W 48VDC inverter
jwrgorman
Registered Users Posts: 22 ✭✭
I have a 900W of PV connected to a Morningstar TS45 (PWM) charge controller connected to a 48VDC pack made up of (4) 12V LiFePO4 batteries in series. Also have a 48VDC 375W Victron inverter attached to this battery bank for AC loads. It was working fine, but possibly it is a set of very sunny days but the Low Voltage Disconnect (LVD) feature which is enabled now seems to keep triggering a lot. does anyone have advice on the TS45 settings to avoid this? Thanks
John Gorman / SolarNetwork Foundation
e:john@solarnetwork.net
Morningstar has very good tech support, drop them a email and I am sure they would be able to help you out. They have always been able to help me.
Good Luck!
