EASUN ISolar SMK 5KW hybrid inverter to charge Lifep04 battery
luqman
Registered Users Posts: 15 ✭✭
Hello everyone, I need a bit of help.
I have been using my EASUN ISOlar hybrid inverter to charge a forklift battery, that was great but i want to upgrade to LIFEPO4 batteries @48v but i am not sure if the hybrid inveter i have is compatble with Lifepo4 batteries. Any advice will be greatly appreciated.
Usually a mppt hybrid inverter should work fine with Lifepo4 batteries. I searched online but cannot find an inverter the exactly same as the one you showed. Found one from EASUN, same 5kw and 80A mppt, and the manual was not easy to read at all. No Lifepo4 battery is mentioned inside...maybe other guys would do better :'(
@BryceFreeman, thank you very much for your attempt, i also did a bit research and could not find anything, so i thought i would ask here.
- 234 Forum & Website
