mppt charger controller max pv volt
robocop
Registered Users Posts: 118 ✭✭
Hi everybody
have 4000w power inverter 48vdc /120vac and a 60a 150v max pv mppt controller .
installed 3 500w panel in series but now the pv is 170v
think it will damage the mppt charger or not
need some advice
Thnkss
Bob
need some advice
Thnkss
Bob
Damage? YesThe controller will likely protect itself and not allow any DC Current (power) from the solar panels through it above the 150 Volts.
should i put the panels in parallel instead of in series? or use only 2 panels instead of 3 ?
forget something: what type of cable to be used from the controller to the batteries?
SumPower said:Damage? YesThe controller will likely protect itself and not allow any DC Current (power) from the solar panels through it above the 150 Volts.I should have said that the controller would "try" to protect itself. Typically any voltage over the max can damage it. If you are in snow country where it gets well below freezing, then the voltage from the panels can get higher the colder it gets. So it is important to know what the typical coldest temp is for your area.Yes, Parallel to reduce the voltage ouput from the panels to a voltage less than the controller max.Any conductor rated for at least 75° C can be used. THHN/THWN
I mean what awg cable should be best between mppt controller and the batteries
Robocop is on an island in the Caribbean, just off the north coast of Venezuela.
Curaçao
What are the panel's specifications (Vmp/Voc/Imp/Ioc)?
The MPPT solar charge controller uses transistors as switches--Exceeding their 150 Volt limit can easily cause the transistors to fail, and on some (few/many/all?) MPPT controllers, they can log the over voltage and void your warranty.
You live in a warm climate (no snow, minimum temperatures year round of ~25C)... So the Voc rating of the panels will ever increase above specs (Voc/Vmp rise as panel/cell temperatures drop to freezing and below).
It appears that your panel Voc voltage is on the order of:
170 Volts Voc-array (?) / 3 panels in series = around 57 volts Voc
With a 150 Vpanel input controller and a 48 volt battery bank, the only "workable" solution is to put 2 panels in series for Voc-array ~114 volts.
For charging your 48 volt battery bank, you need around 72 volts Vmp-array thru 120+ Vmp-array to charge the battery bank. MPPT controllers (almost all) can just "drop" the array voltage to battery bank voltage... They cannot "increase" array voltages below ~65 volts to that needed to run the MPPT controller and charge the battery bank at 58+ Volts...
For a 60 amp controller charging a 48 volt battery bank (with Vbatt max of ~58 volts for FLA type batteries), the maximum "cost effective" solar array would be:
60 amps max charging * 58 volts Vbatt charging * 1/0.77 panel+controller deratings = 4,520 Watt array rough "cost effective" maximum solar array
So, you can run:
2 * 500 Watts = 1,000 Watt array (2 series * 1 parallel string for 2 x 500 Watt panels)
4 * 500 Watts = 1,500 Watt array (2 series * 2 parallel strings for 4 panels)
6 * 500 Watts = 3,000 Watt array (2 series * 3 parallel strings for 6 panels)
8 * 500 Watts = 4,000 Watt array (2 series * 4 parallel strings for 8 panels)
10 * 500 Watts = 5,000 Watt array (2 series * 5 parallel strings for 10 panels)
Note that you could go with a larger array, but you will get "clipping" of controller output current (60 amps maximum current rating) if you go with 5,000+ Watt array (i.e., your 5,000 Watt array will not output its full output on clear/sunny day around solar noon...
What cable AWG to run depends on your array (2/4/6/8/10 panels) and the distance from array to charge controller/battery bank shed... Longer wire runs need heavier cable to keep to "reasonable" voltage drop from array to charge controller.
it is very clear now about the pv voltage.
But only the cable AWG between the Mppt charge controller and the l lipo batteries .
Only thing I can say to your people for you time you take to help others.
Is Gods blessings
Bob -
You need to series wire only two panels per string. Parallel won't yield high enough voltage for your 48 volt system. I would get one more panel and wire up 2s2p.
think will do pair serial and pair parallel as I have one more panel left. As for the cable wire from the mppt controller to the Daly Bms /lipo batteries what type of wire should I use ?
Hopefully, this is what you are referring to. This is 2s2p.
more clearer it cant be thnks
i mean this is for the cable to the LIPO batteries from the MPPT controller
regards
Bob -
robocop said:I mean what awg cable should be best between mppt controller and the batteriesYou can use this Voltage Drop Calculator to determine your wire size.Edit: See BB post below for Voltage Drop.
Between any charge controller, and the battery bank... The suggested maximum voltage drop (at maximum charging current):
12 volt bus: 0.05 to 0.10 volt maximum drop
24 volt bus: 0.10 to 0.20 volt maximum drop
48 volt bus: 0.20 to 0.40 volt maximum drop
Keeping the maximum voltage drop (at max charging current) gives the charger the (close to) actual battery charging voltage--Fast charging, accurate charging....
Too much voltage drop, the charger will cut back on charging current early and slow down the charging (longer time to charge bank).
HI guys how are you today you are helping a lot
A next question about solar panel in parallel, my mppt controller is 60a and 150v max input.
using 2 500w panel in parallel will raise or add the Amp but will it dame the controller or what is the max amp input for these 60a controller?
thnks agian and regards
Bob
- 218 Forum & Website
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
