Mixing MPPT's 80-150 with 100-600
XW+ (48V)
2x MPPT 80 150
SCP
Combox
I have the latest versions of firmware. When I plugged it in I got an error which was duplicate IDs, which was easily fixed. But when I tried to configure it via the web page it does not show up. Rebooting the SCP and MPPT has not helped. I've reverified the network wiring/ terminations.
There are no active PVs on the new controller yet.
When I plugged in the 100-600 the SCP kept beeping until I changed the ID of the first existing 80-150 to a higher ID. I've tried shifting all in case the new one was occupying an existing one, no luck there.
I did find a multi key press that activates Advanced mode. But so far it doe snot seem to make a difference either. Though I was able to copy the batt config from an older controller. It looks good on the SCP...
Hmmm, it should work but the mppt 100a was never tested with combox as it was out of support when the new controller came out.
Since you are new here, you do knowSecurity Notification – Schneider Electric is aware of a vulnerability in its Conext™ ComBox product. Please read this document for further information. Due to product limitations a firmware update will not be provided. We strongly recommend customers to consider upgrading to InsightHome or InsightFacility.
Customers should immediately apply the following mitigations to reduce the risk of exploit:
- Limit traffic on the local network with managed switches
- Do not grant network access to unknown computers
- When remote access is essential, use secure methods such as Virtual Private Networks (VPNs), and ensure the remote access solution(s), as well as the remote computer(s) are kept up to date with the latest security patches.
Part number
- Conext™ ComBox – 865-1058
New Product Announcement –
We’re excited to introduce InsightHome and InsightFacility that provide local system configuration and management as well as live system monitoring for the residential and commercial range of solar products. Click here to learn more!
Note: Conext XW Pro is not supported by Conext ComBox. For monitoring and configuration of your Conext XW Pro, please use InsightHome or InsightFacility.
Data Sheet
Yes, I do know, thanks!
I did come to the realization that I will need to get one of the Insight's.
Fortunately it is also compatible with my XW+ so now it's all about finding the best price.
