How Lipo Battery's Performance Affected By Temperature?
jennyzhang
jennyzhang Registered Users Posts: 31 ✭✭
The optimal level of operating temperature for #lithiumbatteries is 0 to 35℃. The low-temperature environment will reduce the activity of lithium ions, the lipo battery discharge capacity will be weak, and the use time will be shortened. If the lithium battery using in a low-temperature environment for a short period of time, the damage is only temporary and does not damage the battery capacity. The performance will recover when reinforcing the temperature.
However, if the battery is charged and discharged in a low-temperature environment for a long time, metal lithium will be separated out on the surface of the “battery anode”. This process is irreversible and permanently damage to the battery capacity. Like sometimes, at low temperatures, our smartphone will automatically shut down. It is for the purpose of protecting the battery, on the other side, it is also caused by the unqualified and aging of the self-battery.
If you have more opinions and ideas, please feel free to comment below.
  • Wheelman55
    Wheelman55 Registered Users Posts: 274 ✭✭✭
    edited September 2023 #2
    Jenny. Would you comment on storing LiFePo4 batteries at 30c to 35c for 6 months?
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
  • jennyzhang
    I'll share it in a later section.
