Tigo inverter
DanS12345
Registered Users Posts: 1 ✭
Hi all,
I'm considering several inverter options and came across Tigo Energy.
Seems they are fairly new to the inverter market as I haven't found much info on forums about their product.
Does anyone here have experience with Tigo inverters and if so, mind sharing?
Thank you
Thank you
There have been some issues with them from my buds who install roof solar.
Not really a fan of roof solar but I will say I think it is not the best installation when you place electronics up on a hot roof. Just the thermal cycles would be an additional failure mode.
I would rather see a central string inverter used at ground level. Easy to change out and less reason for people to go on your roof."we go where power lines don't" Sierra Nevada mountain area
