DP 60amp breaker in place of SP?
tripster
Registered Users Posts: 14 ✭
My Xantrex PS2524 specifies the use of 60 amp breaker to feed the ac in on the inverter. The inverter is capable of 50 amp pass through. I am having a hard time finding a 60 amp single pole ac breaker. Can one side of a douple pole 60 amp be used?
Thanks,
Thanks,
Re: DP 60amp breaker in place of SP?
Should be OK.
HTH,
Jim / crewzer -
Thank you. I shall move forward with the install!!
