Replacement for Schneider Solar System control panel (SCP)
Dave Angelini
Solar Expert Posts: 7,083 ✭✭✭✭✭✭
In the next few weeks a replacement for the SCP will be available. The model number will be 809 -0922
It will be black in color like the Xantrex version that is used on Freedom Inverters in Marine/Mobile
It is basically the Xantrex version with the Schneider SCP firmware pre-installed.
Thanks Dave
Any idea if it has been updated to be fully compatible with the XW Pro?
Sounds like it they have the same SCP innards, only fully compatible with the older XW series and are intended to replace SCPs that have failed in older systems.Offgrid in cloudy PNW
Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries, Slimline enclosure, Lynk II, AGS, H650, H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
It will never be fully compatible with XWP as there is not enough memory to do all of the Grid coding and Soc that was added to XWP.
It does do alot with XWP and enough for most needed features offgrid. I am happy for my older clients who needed an SCP.
New SCP does all that CSW can do and is a spare for an SCP that has had its buttons pushed too many times."we go where power lines don't" Sierra Nevada mountain area
What a life, putting up with getting your buttons pushed all the time
- 234 Forum & Website
