Spare Components for Schneider Inverters 4048 &6048
Luisoler
Registered Users Posts: 5 ✭✭
Holle - Need to buy components to repair Schneider Inverters, Specially the boards and relays. Any Idea where to buy. Thanks
If you are looking for older inverters and "piece parts", this post has a list of folks that do repairs and may have parts for various brands/inverters:
https://forum.solar-electric.com/discussion/comment/241766#Comment_241766
Where are you located? Most of the big repair companies buy or just keep used equipment to scavenge parts from. Since the charge to safely ship a 120 LB XW is high it often makes sense to replace. xw6048 is 2 generations old and nothing is available from Schneider except replacement with XW 6848pro.Luisoler said:Holle - Need to buy components to repair Schneider Inverters, Specially the boards and relays. Any Idea where to buy. Thanks
Bill's link may help also. The good news is even the old greybox 6048 is well designed for long life and the weak point is the 60A Xfer switching that is often damaged by the owner using incorrect settings. They are soldered in and back in the day the pcb was available for sale."we go where power lines don't" Sierra Nevada mountain area
You may have good luck finding these parts on eBay.
