Series-parallel panel wiring
JYanke
Registered Users Posts: 39 ✭✭
Hello everyone,
Is there an advantage/disadvantage one way or the other for series-parallel wiring of a PV array based on the two diagrams below? The panel specs are as follows:
(1) 80watt panel
Voc: 20.23
isc: 4.68
MPPT charge controller specs
max pv wattage: 700 watts
max pv voc: 100v
max pv isc: 60a
15A double pole breaker on + and - between array and CC
(1) 80watt panel
Voc: 20.23
isc: 4.68
max pv voc: 100v
max pv isc: 60a
MC4 4mm^2 wire from array to CC
diagram1
Total array- (6) panels
voc: 60.69 v
isc: 9.36 a
diagram1
voc: 60.69 v
isc: 9.36 a
Diagram2
voc: 40.46 v
isc: 14.04 a
voc: 40.46 v
isc: 14.04 a
You haven't mentioned system voltage but diagram would work great for both 12 volt and 24 volts. Also with only two strings you don't need to fuse the panels prior to entering the charge controller.
Thanks for the info.System voltage is a 12v battery bank. Im using the breaker between the panels and CC as a means of disconnect purpose more than anything.I guess Im looking more at the advantage/disadvantage of having a higher voltage with less amperage as shown in diagram1
versus the slightly lower voltage and higher amperage as shown in diagram2.
Does it really matter either way with having a MPPt controller? -
More or less... A good starting point is for 2x the battery bank charging voltage (i.e., 15.0 volts charging => 30 Volt Vmp array)...
Going with a lower voltage array, the MPPT becomes less efficient. And with a, for example, 18 volt Vmp-array and 15.0 volt charging battery bank, on warm/hot days, MPPT adds "nothing" energy wise (just behaves like an expensive PWM type charge controller).
MPPT controllers only operate in "MPPT Mode" when the Vmp-array voltage is (roughly) at least 1.3x battery charging voltage (remember, as solar panels heat up, Vmp-array falls).
One huge advantage with MPPT controllers is that you can run the solar array at much higher Vmp-array working voltages. This reduces the array current, fewer parallel strings and fewer series protection fuses/breakers/combiner box circuits), and alltrows you to use much smaller AWG cables and send power for 100's of feet relatively cheaply (again smaller AWG cables).
The disadvantage is that MPPT controllers are slightly less efficient at higher Vmp-array voltages (something like 1% or 2% less efficient)... Not enough to worry about, but you still need to ensure good cooling/ventilation for the MPPT controllers, especially with higher array voltages.
An example from Outback:
https://www.solar-electric.com/lib/wind-sun/Flexmax-manual.pdf
Note that other vendors may derate output current at higher Vmp-array voltages. And always design so that Voc-array-cold does not exceed Vpanel-max input voltage for the charge controller.
- 621 Discussion Forums/Café
