Water turbine
SethandBecca
Registered Users Posts: 20 ✭✭
Does anyone on this forum have experience with water turbines? I am curious what sizes are available and how much of a head is required for a water turbine? Are they efficient or not?
Here's a link for calculating theoretical available power in flowing water: https://greenbugenergy.com/get-educated-skills/measuring-power. Generally though, the lower the head the more water flow you need, and vice-versa for any given power level. Efficiency is a relative term and depends on the installation and the type of turbine. Theoretically I should see about 400 watts from my pelton wheel system but in practice I see only about 125, but then at 40 ft of head I'm at the bottom of the efficiency curve for a pelton. Still, running 24/7, 3 KWH per day is nothing to sneeze at.Rance
Schneider XW6848, (2) MPPT60-150, two 2600 watt arrays, 1182AH@20Ahr FLA battery, Winco PSS8 8KW backup generator w/AGS, 125 watt Pelton hydro.
- 230 Forum & Website
