Can a 12/24v solar panel charge a 48v lithium batery
ankitrauthan
Registered Users Posts: 3 ✭
Hi
Plz help me I want to install a solar charging system on a electronic vehicle with limited roof, it have 48v lithium battery pack with 100ah
Question 1: can a 12/24v Canadian solar panel 240watt 8amp be able to charge the batteries and in how much time, 5peak sun hours
Question 2: can a 48v local brand solar panel 580watt 7amp be able to charge the battery with 5peak sun hours
Plz answer
Plz answer
In general, most solar charge controllers need the solar array Vmp-array to be a higher voltage than the battery bank charging voltage (MPPT controllers are typically "buck mode" or voltage dropping type switching power supplies).
The only "purpose designed and built" "boost type" solar charge controllers I am aware of is the GenaSun brand:
https://genasun.eu/collections/genasun-boost-mppts
If you want to charge a 100 AH battery pack from zero to 100% SoC in five hours of full sun (array tilted towards sun, summer in most locations- 100 AH * 58 volts charging * 1/0.77 panel+controller derarings * 1/5 hours of full sun per day = 1,506 Watt array minimum
Regarding the Hours of Sun per day--Guessing Dehli Inda, flat roof (no tilt):
http://www.solarelectricityhandbook.com/solar-irradiance.htmlDelhi
Measured in kWh/m2/day onto a horizontal surface:
You do have >5 hours of sun per day (flat panel to roof)--Except for "winter".Jan Feb Mar Apr May Jun 3.71
4.64
5.73
6.17
6.39
6.04
Jul Aug Sep Oct Nov Dec 5.19
4.78
4.99
4.79
4.07
3.45
Questions?
