Submersible pump power consumption
I decided to purchase a power meter to plug into all my appliances to see how much power was actually being used versus what I projected them to use. The one appliance that surprised me the most was the well pump. According to the meter, it averaged 4 KWH for the couple of days I had it plugged in. This is way higher than the 500 WH I figured it would use. Our cottage has about 5-6 people staying there the whole time. Is anyone else seeing these same numbers for their well pump? I should state that the submersible pump is a 110V 11.5 Amp that we stick in the lake, not in a well and it works great.
Powering-20.5 CuFt. Fridge, 1 HP Submersible water pump, UV, Washing Machine, Gas Dryer, Gas Stove, Lights and Receptacles
Off Grid Cottage on lake in Northern Ontario 46˚N
How many hours per day is the pump running?
- 110 VAC * 11.5 Amps = 1,265 VA
- 1,265 VA * 0.80 Power Factor (guess) = 1,012 Watts
- 4,000 WH per day days / 2 days = 2,000 WH per day
- 2,000 WH per day / 1,012 Watts (est. running Watts) = 1.98 ~ 2 hours of pumping per d
Guess at water pumping can be from 10 to 50 GPM or 600 to 3,000 GPH.
2 hours per day guessing at 1,200 to 6,000 GPD of water usage?
If each person used 40-100 GPD, 6 people * 40-100 Gallons per person per day = 240-600 GPD
Use a 5 gallon bucket and time how long it takes your pump to fill the bucket... Figure out GPM pumping rate (full flow, and at 40 PSI). Do you have a pressure tank?
Does that sound anywhere near reasonable?
So here is the water pump we are using
It states 33 GPM. I cannot do the bucket test since I have already left for the winter. At 2 hrs of pump time, that would be 3960 Gallons per day or 660 Gallons per person per day. This site
https://water.phila.gov/pool/files/home-water-use-ig5.pdf
says the average person uses 101.5 GPD and that’s with toilet use, which the cottage does not have. So should I not trust what the power meter reads? My hope was to use this meter to get accurate numbers for sizing future battery banks.
We have a 33 gallon pressure tank and the draw down takes about 2 min. The cottage has a kitchen sink, bathroom sink, shower and clothes washer. We wash dishes in the sink which I would assume uses more water than a dishwasher.
1860 W (6) Rensola JC310M, Classic 150, 430AH@24V (8) Deka DSGC15 FLA's, Victron Phoenix Multi 24/2500 Inverter
- 234 Forum & Website
