48v Off Grid system
dreamcr52
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
We currently have a off grid system with 2 Magnum Sine MS4448PAE inverters, 2 midnight Classic charge controllers, 18 295W panels, 12 320w panels, plus a Primus wind turbine and a 12000w Kohler generator and 8 Simpliphi 48v LiFePO batteries. We're thinking of adding a third Magnum Sine MS4448PAE, Will our system need any other modification to add the new inverter?
OUT OF STOCK at Wind & SunSKUMS4448PAE
Due to supply chain delays, Magnum inverters are currently two to six months behind schedule. If you need something sooner, we have put together a list of our recommended alternatives. Please email us or give us a call if you have any questions.
Welcome to the forum Dreamcr52,
Can you tell us a bit more about your battery bank (model/voltage/AH rating/etc.)?
https://www.solar-electric.com/residential/batteries-battery-storage/deep-cycle-batteries.html?manufacturer=541
They seem to be rated at C/2 maximum continuous discharge and charging rate (in general).
Need to make sure your bank is not subjected to "excessive" current (charging and discharging).
