Xantrex gt3.3 n insufficient solar
mosierpat
Registered Users Posts: 13 ✭✭
Two identical inverters, one working one says insufficient solar. So I swapped the solar inputs and the same inverter had the same error and the other worked fine. So. Is there a fuse or something I can just switch out or just replace
The unit has internally failed ( likely the first stage DC converter ) with that error, being a gt3,3 it must be close to 15 years old?. unforntatually current Xantrex is no longer in that market and what was that market was sold off too Schneider Electric long ago and that line of inverters is discontinued close to a decade ago. Good news is many low cost options these days for replacement options
Yep. Had to try though. Thank you
