RV Off Grid
Suntrekker
Registered Users Posts: 150 ✭✭
Now that the off-grid solar system is online (no generator), I’ll share performance and dispersed camping adventures! And for those who wish to visit my build thread…. https://forum.solar-electric.com/discussion/356634/life-cell-internal-resistance#latest
640W REC Mono Array 280AH 24V LiFePO4 Battery
Shading on panels? (A/C unit and "rear panel? Panel to Panel shading at lower sun angles?)
There’ll be no shading, the panels are far enough apart. And the tilt angle is adjustable if necessary.
Sorry for not posting more often, but here is an update on my RV off-grid system. After 4 years, it rocks without a BMS! The Outback FM60 and cell equalizer do the job. But a BMS is important; it depends on the system size and design.
A well designed and installed Off Grid systems--It Rocks!
…always good to hear from you. Best regards
