What connectors are folks using within J Boxes for the transition ...to THWN ?
Phatz
Registered Users Posts: 1 ✭
What connectors are folks using within J Boxes for the transition from Enphase Q Cable to their stranded THWN ?
Polaris tap connectors / Twist connectors / WAGO levers / ....
While it doesn’t answer your question, I’m planning on using my two j-boxes (one for each string) as a “pass through” to a combiner box in the attic. To make that feasible I ordered two 50’ male/female extension cables, then cut them cut in half leaving a total of four 25’ cables that are wired together within the combiner box.
Polaris grey connectors.Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
