Bluetti AC200 MAX Want to max solar inputs
jim_grove
Registered Users Posts: 2 ✭
I have an Bluetti AC200 MAX with 2 B230 batteries.
I would like to max the solar input and provide at least 50% extra for the cloudy days in Northwest Mississippi. I am trying to find fixed panels to accomplish this.
I need all the help I an get. I am overwhelmed trying to figure this out.
With the VOC limit and the AMP limit is it possible to max the ports?
Any recommendations for panels to accomplish would be appreciated.
The 200 MAX has two ports that can be used for solar input.
1 PV Port
Power of input 900W
Over-Voltage Protection 145VDC
MPPT Voltage Range 10-145VDC
Current 15A Over-current: 15.2A ± 0.3
2 AC charging port using the charging enhancer
D050S DC Charging Enhancer
Input
12-60 VDC
current 10A MAX
Output
16-58 VDC
8.2A MAX
500W MAX
1 PV Port
Power of input 900W
Input
12-60 VDC
current 10A MAX
Output
16-58 VDC
8.2A MAX
500W MAX
Welcome to the forum Jim,
This is sort of the problem with "black box/all in one" systems. We really do not have a good idea of what they exactly do.
In general, MPPT (maximum power point tracking) solar charge controllers will take any input voltage (within spec. range) and efficiently take the higher voltage/lower current from the solar array and down convert to the lower voltage/higher current to charge the battery bank (and run DC loads).
A typical MPPT controller will also automatically limit its output current to is rated maximum--Safely and efficiently. So, for a 145 Vpanel max input--You need to look at the mininum ambient temperature and calculate the voltage rise of the panel (Voc-cold). Pretty safely, unless you are in sub 0F weather, you can use a Vmp-array of around 100-110 Volts maximum.
And you and parallel as many series strings of panels in parallel as you want... Typically the "cost effective" maximum in parallel is around 1/0.77 or 1.33x that maximum current*voltage (Watts) your system can accept.
Now, too much current even on the input of an MPPT solar charge controller--You do run into safety limits--Too much solar panel current could burn out the input wiring of the controller if there is an internal short/failure. So that is one reason that you do not want to exceed the input current maximum rating.
Without knowing more about the actual MPPT controller--We do not know if the maximum input rating is the Max rating of the solar array (no more panels or damage would occur), or if thisd is simply the Max current the MPPT controller will draw...
We can play some math and you can decide if you want to "risk" your very expensive black box or not. But this is how it could be done.
For example, use Vmp~30 volt solar panels (very common voltage). And put 3x of those in series for Vmp-array = 90 Volts.
Your controller has an input rating of 15 amps, so the Pmp rating of the array would be:- 90 Vmp-array * 15 Imp-array = 1,350 Watt array
- 1,350 Watt array / 3 panel strings = 450 Watts
- 450 Watts of panels / 2 parallel strings = 225 panels
I cannot tell you this would be "OK" to do and keep your unit "reliable"--But it could work from a generic approach to how we normally work with MPPT controllers.
The box is rated for something like 1,400 Watt maximum charging power (solar+DC input). The DC input (car charging, etc.) is limited to 8.2 amps... Not sure the input voltage range... Looks a little unusual:
https://www.bluettipower.com/products/ac200max-power-station
Input max: 12-60 VDC, 10 amp max
Output max: 11.5-14.5V; 23-29V, 7.9-8.4A
I would have thought it would be rated to 11.5-29 Volts--Which would be nice with a "12 volt" solar panel (Voc~22 volts, Vmp~18 volts)... But that "dead zone" in the spec--So cannot say if using solar panel would work or not... And is that ~8 amps @ 13 volts and 26 volts or what?- 8 amps * 13 volts = 104 Watts
- 8 amps * 26 volts = 208 Watts (?)
rthttps://www.bluettipower.com/products/dc-charging-enhanncer-d050s
16-58.8VDC, 8.2 amps Max, 500 Watt Max- 500 Watt / 8.2 Amps = 61 Volts output(?)
- 8.2 amps * 58.8 amps = 482 Watts max(?)
Problem is that these have pretty narrow and a bit "unbalanced" operating ranges... To get 500 Watts max, you have to run at max input voltage. If you go over max input voltage, one would assume that the converter would be ruined.
And the DC input port to the AC 200 Max would appear to take a wider voltage input than the 12/24 volt input listed--But this depends on which port we are looking at??? Solar vs DC port?
This is one of those situations where you really need to talk with the manufacturer about how to maximize your solar input charging power.
There are a lot of nice videos out there where folks are doing some pretty well documented product reviews (lots more than just the one below):https://www.youtube.com/watch?v=fwSbuHHbj6A
You have to be really careful here... Normally, we would just attach a MPPT Solar Charger directly to the BlueTTI battery bus. But because these devices have Lithium Ion batteries--And you cannot bypass the BMS (battery management system), and the manual says exactly this (do not charge through battery bus ports). If you bypass the BMS you run the risk of destroying your batteries (and possibly risk of fire) if you over charge them.
At this point, I would guess this are a bit "under powered" from a charging point of view...The limits of the charging ports and that you cannot charge via the battery bus--And the limits on charging volts/amps (you only get maximum charging Watts at Max input voltage and current). And there is only one "AC port" (which looks like a 1/2 power rating 1/2 voltage of the "solar" port).
Solar panels have a pretty wide range of output voltage (hot/cold panels, loaded vs open circuit voltage, etc.)... It is difficult to figure out a way to increase charging wattage much more than you are limited to with their accessories.
Bill,Thank You for your response. I hope you find this. I could not figure out how to tag you.I live in northwest Mississippi. Winter temperature lows above 0F. Summer can be above 100F.I think I understand most of what you are saying. Would it make any sense to put a MPPT solar charger between the panels and the Bluetti? Could an MPPT controller be configured to output only what the Bluetti can take as input in terms of voltage and amps? I am probably showing my ignorance, but I see where there appears to no leeway in getting the rated input values. I know people have said on the Bluetti site that you can go over on amperage, and the Bluetti will only use the spec amps. No one has indicated a max amp and the the specs indicate that you can not go over. Since they have a range in input voltages they must be adjusting it to charge the batteries. There is a lot I do not understand.I was hoping to run a refrigerator, freezer and a few small items all year long. A lot of clouds and rain in the winter. The refrigerator and freezer pull about 300 watts together. I have tested it with 3 of Bluetti 200 watt folding panels and got about 450 watts max in the PV port. I can not run the 3 Bluetti panels through the D050S in series since that would go over the voltage limitation. The D050S charge controller goes through the AC port.On the confusing gap in the voltages I think they are saying you can charge from a 12 volt or 24 volt battery system in a vehicle. The input for a vehicle is through the PV port or the D050S charge controller and would be controlled by their voltage ranges.I forgot to mention that it is also possible to charge the B230 batteries using the D050S. ($150 each) That would require disconnecting the B230 batteries from the AC200 to charge. If they are connected the charging is through the AC200. Would be a pain to do every day when the sun is shining.
No problem Jim, our forum is small enough that we can pretty much keep up with the posts most of the time.
Your questions:- I live in northwest Mississippi. Winter temperature lows above 0F. Summer can be above 100F.
We can calculate the voltage spread more precisely... Just need the panel specifications. But for a rough rule of thumb in a very wide range of temperatures (hot desert to cold winter mountains), take Vmp*0.80 for Vmp-hot, and 2x Vmp-hot for Voc-cold. It gets you pretty quickly to narrow down your choices and details of the math.
Pmp = Vmp * Imp (power maximum power = Voltage @ maximum power * Current @ maximum power)
Current is not very temperature sensitive and moves in the "opposet" direction (temperature rises, Imp rises). But since the temperature sensitivity is about 1/5 to 1/10 as much as Voltage--We pretty much ignore current temperature changes.
Vmp-hot needs to be higher than the battery voltage. And Voc-cold needs to be lower than max input voltage (when the controller is drawing zero current).- I think I understand most of what you are saying. Would it make any sense to put a MPPT solar charger between the panels and the Bluetti?
There are DC to DC converters that may work--But this gets into a lot of other issues. Most DC-DC converters are not MPPT type input (maximum power point tracking). If they "over load" the solar array, the DC converter can "collapse" the solar array voltage.
MPPT controllers track the Pmp=Vmp*Imp equation/results. And will only draw enough current to pull Varray to Vmp-array (if that makes sense). The output power from an MPPT controller is therefore based on the Array's power output.
A "standard" DC to DC converter trys to keep the voltage on the output side steady (Pout=Vout*Iout). If the array power is > output power (battery charging) power... All is OK. But if the battery "wants more power", the DC will simply pull more current. And once Iinput > Imp, then Varray will fall. And P=V*I, as V approaches "zero volts", Pout approaches "Zero Watts" (self fulfilling prophecy).
Think of an MPPT controller like a automatic transmission on a car. It matches engine power to wheel power by controlling Engine RPM to Wheel RPM as needed.- Could an MPPT controller be configured to output only what the Bluetti can take as input in terms of voltage and amps?
Yes, the MPPT controllers can have maximum current output programmed for lower levels--But voltage "regulation" is really a longer term average of battery voltage (seconds or more of averaging).
If you have too large of an array with a large MPPT charge controller and a "small" battery bank, the battery bus voltage can exceed spec'ed limits.- I am probably showing my ignorance, but I see where there appears to no leeway in getting the rated input values.
When you have "complex" black boxes--It is hard to tell from looking at the paper marketing specifications which are the "hard limits"--We can only guess at them.
With MPPT Solar Charge controllers, typically the Vpanel input current is the same or somewhat close to the Vouput rated current. For example:- BlueTTI: 500 Watts @ 59 volts @ 8.2 amps
- Power = 59 volts * 8.2 amps = 484 Watts
- 18 volt array Vmp * 8.2 amps = 148 Watt maximum from "lower voltage" array or other DC source (12 volt car charger, etc.).
https://www.solar-electric.com/motr60ampmps.html
The controller is probably rated max input current of 48-60 Amps (tried to find, but could not!!!!!). Anyway, the input current is near or the same as the output current rating.
So that means the controller will "accept" input voltage from Vbatt+several volts to 145 volts max. Meaning that the controller can output max rated current with any within spec solar input:- 29 volts charging * 60 amps charging = 1,740 Watts to battery
- 1,740 Watt charging / 30 Volt Vmp-array = 58 amp input Imp array
- 1,740 Watt charging / 90 volt Vmp-array = 19.3 Amp input Imp array
- I know people have said on the Bluetti site that you can go over on amperage, and the Bluetti will only use the spec amps. No one has indicated a max amp and the the specs indicate that you can not go over. Since they have a range in input voltages they must be adjusting it to charge the batteries. There is a lot I do not understand.
- I was hoping to run a refrigerator, freezer and a few small items all year long. A lot of clouds and rain in the winter. The refrigerator and freezer pull about 300 watts together. I have tested it with 3 of Bluetti 200 watt folding panels and got about 450 watts max in the PV port. I can not run the 3 Bluetti panels through the D050S in series since that would go over the voltage limitation. The D050S charge controller goes through the AC port.
AC inverters can be big and fairly cheap. The battery bank--Expensive (or even 2-4x expensive with Li Ion). Most people get a large (or too large) AC inverter and to small of battery bank and too small of solar array. And they need to use a genset to keep up (especially during winter)--And can end up "murdering" their battery banks with over discharging.
I will run through a quick design for you to give you an idea how it is done. But do it in a second post.- On the confusing gap in the voltages I think they are saying you can charge from a 12 volt or 24 volt battery system in a vehicle. The input for a vehicle is through the PV port or the D050S charge controller and would be controlled by their voltage ranges.
Buck mode: Drops Input voltage to output voltage (24 volts input to 12 volts output)
Boost mode: Increases input voltage to output voltage (12 volts input to 24 volt output)
Buck/Boost mode: Can take "any" input voltage to output voltage (i.e., 12 to 48 VDC in to 24 volts out)
It sounds like the BlueTTI uses buck/boost converters (probably) in at least some of its power circuitry.- I forgot to mention that it is also possible to charge the B230 batteries using the D050S. ($150 each) That would require disconnecting the B230 batteries from the AC200 to charge. If they are connected the charging is through the AC200. Would be a pain to do every day when the sun is shining.
And feel free to ask more questions. You are jumping into the deep end of the pool trying to learn how to swim (bought hardware first, then trying to configure to meet your needs).
Will go through the "math" in the next post and see if the BlueTTI + various options (battery banks, charging ports) could do what you want.
https://www.amazon.com/s?k=kill-a-Watt+meter
And note some appliances use more or less power seasonally (refrigerators and freezers use more power in hot room, making ice, etc.).
You have the average running power of ~150 Watts each fridge/freezer. But the total energy per day could be:- 300 Watts * 0.50 duty cycle * 24 hours per day = 3,600 Watt*Hours per day
Lets pick 3,600 WH per day (good round number for 2x compressor coolers and some random LEDs, cell charging, small water pump, etc.).
I will do a "rule of thumbs" design using flooded cell lead acid batteries. You can probably get away with about 1/2 that AH rating in Li Ion--But that is for another post/day. 2 days of storage and 50% max discharge (works well for FLA batteries):- 3,600 WH per day * 1/0.85 AC inverter eff * 2 days storage * 1/0.50 max discharge * 1/24 volt battery bank = 706 AH @ 24 volt FLA bank nominal
For solar charging, suggest 5% minimum for weekend/sunny weather systems. And 10-13%+ (up to 20% or so) for full time off grid systems (larger battery bank, need larger solar array for "happy batteries"):- 706 AH * 29 volts charging * 1/0.77 panel+controller deratings * 0.05 rate of charge = 1,329 Watt array minimum
- 706 AH * 29 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 2,659 Watt array nominal
- 706 AH * 29 volts charging * 1/0.77 panel+controller deratings * 0.13 rate of charge = 3,457 Watt array "typical" cost effective maximum
http://www.solarelectricityhandbook.com/solar-irradiance.htmlMemphis
Measured in kWh/m2/day onto a solar panel set at a 55° angle from vertical:
Now, lets guess you will either use less power (colder weather) and/or backup genset for December (3 hours of sun per day is still pretty good harvest):Jan Feb Mar Apr May Jun 3.26
3.71
4.49
5.17
5.08
5.29
Jul Aug Sep Oct Nov Dec 5.47
5.36
5.28
4.75
3.58
3.13
- 3,600 WH per day * 1/0.52 off grid lead acid AC power * 1/3.13 hours of sun per day = 2,212 Watt array December "break even"
- 3,000 Watt base loads * 1/0.52 off grid AC efficiency * 1/3.13 hours of sun * 1/0.65 base load fudge factor = 2,836 Watt array @ 65%
- 3,000 Watt base loads * 1/0.52 off grid AC efficiency * 1/3.13 hours of sun * 1/0.50 base load fudge factor = 3,686 Watt array @ 50%
So just a back of the envelope calcuation seems to indicate that ou would be hard pressed to get enough solar power on the BlueTTI to run during winter time.
Guessing that you need 2,659 Watt array minimum (10% rate of charge) to 3,685 Watt array (try to run with near zero genset usage).
If this is for an RV--That is a lot of solar to put on the roof. And a large battery bank to carry around (LI Ion would make it smaller/lighter).
WIth very efficient refrigerator/freezers, you might cut the power needs by a fair amount (25%+ or more?) from my guesses.
Anyway--There are still a lot of details to work out--But that will give you some idea of what the variables and the results work out as...
- 228 Forum & Website
- 618 Discussion Forums/Café
