Disk Full - BenQ AUO Solar 19.M2M01.002 > Monitoring System for AC Unison
greenftechn
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
Online monitoring for this unit is defunct, so a client who had this installed over 10 years ago needed direct access to the web interface. I connected it to his WiFi network, and hit the IP Address of the unit, only to see a disk space error (< 1% free space), with most of the web functionality gone as a result.
There is no way to fix this from the web interface (that's obvious), but I may be able to SSH into the unit and clear some temporary files. Looking for an SSH login with SU access or other help to fix.
I even have a web server that I should get entry to every few days, so I even have SSH enabled on it. My advice might be to apply knockd to installation port knocking, after which write a brief bash script to ssh into the system. It's nearly a second password, that humans might not even assume of. Also, git gud at iptables.
- 230 Forum & Website
