Adding more solar panels
2Brooktrout
Registered Users Posts: 3 ✭
My system currently has 4-Rec Twin Peak 310 watt panels (Voc 39.8, Vmp 33.5, Imp 9.26) in a single string powering through a Magnum PT-100 controller ( 224 volt max). I would like to add more panels but the ones I installed are not available. Can I add 4 more similar panels by making another string of 4 panels and running through a combiner box? Wiring from the panel combiner box is sufficient for the added amperage but the Voc of the two strings would be different by a few volts. Would it be better to break up my existing string and make two strings with 2 new and 2 old panels so the end operating voltages would be similar?
1.2 kw panels, 430ah -24v battery, MSH-4000RE/ MMP-250-60, PT-100CC, ARC-50 remote, 2kw Honda
Generally you need panels within 10% of the original specs.
- 232 Forum & Website
