Solar output calculator
Bluedog225
Registered Users Posts: 27 ✭✭
Good morning,
I’m looking for advanced solar calculator
I’ve been doing a lot of research into solar for an off-grid system at mycmy workshop.
If the total system cost works out, I’m planning on covering the flat roof with panels. 54 panels (9 strings of 6) with 330 watts nominal output. The roof slopes west (ish) at about 6 degrees.
I’m looking or a calculator or estimator for panel output throughout the day. An hourly basis would work.
Overall, during the summer months, I’ll have a 90+% chance of a little over 5 hours of max output at my location so getting my total production calculated is straightforward.
But I’d like to know how long the array will produce enough to offset the air conditioner draw. The goal being to understand the necessary battery storage to run the AC all night.
For example, how long will a 17,000 watt (nominal) array produce at least 2000 watts as the sun rises and sets?
Does anyone know of a way to make this estimate? I’ve been looking around but haven’t found it yet.
Ideally, a formula or calculator that takes into account longitude, latitude, and panel orientation that outputs percent of rated wattage actually produced by each hour on a given date.
Tom
Tom
Hi Tom,
Try this:
https://pvwatts.nrel.gov/version_6.php
And your PV string configuration will often depend upon the requirements dictated by the inverter (or charger) to which the strings connect
FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
That is just what I needed. Thanks Vic!
