Tim Economu
706jim
Solar Expert Posts: 529 ✭✭✭✭
Looking for contact info for Tim Economu former employee of Trace so I can send him a message.
Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
Going back in time. I had contact with him but can't find it. I think he did alot of Trace equipment design. I found someone who might be him? Usually the county will give you a snail mail for property owners. Good Luck and say Hi from Dave.
http://assessor.islandcountywa.gov/propertyaccess/Property.aspx?cid=0&year=2018&prop_id=118232
I'll try contacting him through regular mail. Thanks for looking this up for me Dave.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
This one may be faster and you are welcome! He was a big help to me building an offgrid Telcom back in the day.
https://soundwaterstewards.org/sw/2020/?q=page.pr.5953
Tim and I connected! What a wonderful guy and a privilege to speak to the designer of my wonderful Trace DR1524.
Thanks to Dave Angelini for helping me find Tim.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
