New F-150 pickup with integrated AC inverter and Li Ion battery bank
BB.
Super Moderators, Administrators Posts: 33,744 admin
Looks pretty neat.
Three different onboard generator systems are available. F-150s with
conventional non-hybrid drivetrains get a 2.0-kW system, while hybrid
trucks get upgraded to 2.4 kW or, optionally, a massive 7.2 kW of power,
made possible by the hybrid's 48-volt lithium-ion battery pack. Ford
claims that the top-spec 7.2-kW system can power a plasma cutter, TiG
welder, chop saw, air compressor, angle grinder, and work light,
simultaneously. That mobile welding shop can run for 32 hours
continuously on a full tank, making all-day, heavy-duty work possible.
If you don't need that much wattage, Ford says the 2.4-kW system can run
a jackhammer or a mobile theater setup complete with a projector,
loudspeakers, and popcorn machine for up to 85 hours....
Bill
That is nice ! You could also just live offgrid, and do all of that, without fuel, for alot less than 43K$
