Over paneling the FM80
2»
  • Apica
    Apica Registered Users Posts: 38 ✭✭
    The wire run from the CC to busbar is now roughly 3ft, I'll leave it as is.
    Bill I finally got that Klein Tool clamp meter you recommended and it's awesome. It's definitely a must have item, thank you.
    System A
    Victron Multiplus II 48V|3000VA Inverter || 4,980 Watts JA Solar Panels || Outback Flexmax 80, Outback Flexmax 60 || 2 EG4 48V 100AH Lifepower 4 Batteries V1 & V2 || Trimetric 2030 || Raspberry Pi running Venus OS.
    System B
    Victron Multiplus II 24V|3000VA Inverter || 4,160 Watts Intenergy Solar Panels. || Outback Flexmax 80A, Midnite Classic 150 || 2 EG4 24V 200AH Lifepower 4 V1 LifePo4 Battery. || Trimetric 2025 || Midnite E-Panel || Raspberry Pi Running Venus OS.
  • Wheelman55
    Wheelman55 Registered Users Posts: 281 ✭✭✭
    I’ve found these tin plated copper sleeves to be useful when tightening fine stranded wire into screw down terminals. They make 3 sizes and come in 10 packs.
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 650ah LiFeP04 battery bank - 5 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
  • Apica
    Update: My system has been holding up nicely since over paneling the FM80, no problems to report.
    System A
    System B
