Can I use capasitors instead of batteries for off grid solar?
robert1701
Registered Users Posts: 12 ✭✭
I saw these 12V 500F capacitors. Could I use these instead of a battery to store solar electricity for off grid use?
The short answer is probably not....
The actual energy storage is a bit more complex... Need to know the Min/Max capacitor voltage, the x,xxx Farad rating, and use the equation:- 1/2 * x,xxx, Farad * (Vmax^2 - Vmin^2)
- example: 1/2 * 500F * (14.5v^2 - 10.5^2) = 50,000 Watt*Seconds
- 18,000,000 WS / 3,600 seconds per hour = 13.9 WH
- 13.9 WH / 12 volt nominal = 1.2 AH @ 12 volt battery equivalent
If you only need that small amount of stored energy (compared to 2x 6 volt @ 200 AH "golf cart" batteries in series making a 12 volt @ 200 AH for around $200)--It could work... But you really need to know your energy needs. And it is hard to beat Lead Acid and Li Ion batteries (and other chemistry types).
