Grid tie system, with off grid battery.
smalltruck
Registered Users Posts: 11 ✭✭
I am looking for some answers. First the setup.
I have a grid tie SolarEdge system that was installed by a company and everything is running fine. I also have a small off grid system that I set up to run my outdoor wood boiler with my old panels. The older panels 800watt system with MPPT controller charge and 660AH 12volt battery bank which runs an off-grid inverter to power my wood boiler.
So here is the question my off-grid portion makes more power then the wood boiler needs. Can I set a small plug and play grid tie inverter to come on a 13.5 or so volts to use the otherwise wasted power. And secondly will it create any problems with my existing SolarEdge HD-Wave inverter?
Any great advise will be welcome.
Thanks all,
Thanks all,
For an off grid/full time solar power system, recommend 10%-13%+ rate of charge:
- 800 Watt array * 0.77 panel+controller deratings * 1/14.5 volts nominal charging voltage = 42.5 Amps charging current
- 660 AH * 0.10 rate of charge nominal suggested = 66 Amp recommended
- 660 AH * 0.05 minimum rate of charge suggested = 33 Amp minimum
Assuming you are around Flint Mi, fixed array, south, titled for max winter harvest (wood boiler):
http://www.solarelectricityhandbook.com/solar-irradiance.htmlFlint
Measured in kWh/m2/day onto a solar panel set at a 32° angle from vertical:
(Optimal winter settings)
An 800 Watt array in December, average daily sun is 2.69 hours:Jan Feb Mar Apr May Jun 3.01
3.58
4.07
4.23
4.27
4.43
Jul Aug Sep Oct Nov Dec 4.59
4.40
4.38
3.68
2.68
2.69
- 800 Watts * 0.52 typical end to end off grid solar system eff * 2.69 hours of sun = 1,119 Watt*hours of 120 VAC power average per day for December
If your second Inverter is used much during the winter, I would be very careful on energy usage. If you are doing this in summer, probably not as big of issue.
Comments on my guesses/energy usage/location/etc.?
- 231 Forum & Website
