CU200 “CONTROL INDICATOR” led flashing??? Help!
mikezx
Registered Users Posts: 3 ✭
Hi guys I have a 2.5-2 with a Cu200 and 6 GF270 and yesterday I go to the ranch and y noticed the pump stoped, no error code in the cu display and te tank empty. So I open up the cu 200 and found that the control indicator light is flashing. I wonder if the cu is foulty or the pump. Any data would be useful!!! Thankss
Mikezx, try this disconnect from the cu200 and apply 110 volts to the pump and see if the water flows.
Hope it works. GeorgeOff grid for 20 years. 5KW panels, Trace sw4024, Bergy XL1 wind generator, 3 EG4 Lifep04 200amphr batteries 3 SQF 2 well pump, 12kw back up gen. Not easy living in the wilderness but it keeps you busy -
Hi George thanks for answering!! . Maybe the pump is gone. I think there’s a problem in the cable joint perhaps moisture had made a shortcut. Hope the pump still works with the protection the manual says it has.geosierranevada said:Mikezx, try this disconnect from the cu200 and apply 110 volts to the pump and see if the water flows.
