Solar Panel to 12v fan
midijeep
midijeep Registered Users Posts: 102 ✭✭✭
I want to run a 12v dc fan with a panel.  I want to avoid the fluctuation of the panels power by connecting it directly to the 12v dc fan.  What do I put in between panel and dc fan to give the dc fan regulated power?
  • 706jim
    706jim Solar Expert Posts: 527 ✭✭✭✭
    A battery
    Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
    BB. Super Moderators, Administrators Posts: 33,726 admin
    You can use an oversized array (2+x larger than needed in wattage) and get a buck mode DC to DC converter (takes variable voltage/current input, fixed voltage (or current) output).
    https://www.amazon.com/s?k=dc+to+dc+buck+converter+switching+power+supply
    The larger the solar array, the less clouds will affect the fan speed, and the closer to sunrise/sunset you can operate the fans.
