Portable Wind and solar hybrid offgrid
kewl0069
Registered Users Posts: 4 ✭
I built a portable wind and solar hybrid system that I tow behind my camper or truck and park anywhere I wish
And this monster powers anything i wish with out problems.i have a 4 300 watt solar panels with solar tracking system that can fold down like awning for transport and also 3 200 watt suitcases with folding legs total 600 watt array 120v systems 1200 watt array I have a 200v 100 amp EPEVER mppt controller PV input is 8 awg mc4 connects to copper bus bar then 1/0 awg temco welding cable to 80 amp 100 % duty cycle outback breaker 1/0 awg to pin type terminal into mppt controller then mppt controller battery connection to bus bar 2/0 temco welding cables to 125 amp 150v outback 100.% duty cycle breaker then to copper bus bar then 4/0 cable to battery bank far left negative terminal and far right positive terminal. The 600 watt array run is 8awg temco welding cable mc4 to copper bus bar 1/0 awg temco welding cables to 80 amp breaker midnight solar quad box then 1/0 to EPEVER 200v 80amp mppt controller then to parallel copper bus with 100 amp mppt controller then to 4/0 awg cable to battery bank. The custom box has a temperature controlled relay board that turns on cooling system inside this custom box it has 2 mt50 remote meters with out door see through covers. And also custom led lights hooked to bus bar and fused 5 amp fuse and rocker switch .the solar tracking system is a single axis east to west configuration using linear actuators and a custom prototype superstrut and emt pole system and cone nuts and brackets and square washers to mount solar panels it looks good and is tough.the system has 2 power inverters on the 1410 AH 12v bank made of 12 crown CR-235 6v deep cycle batteries and 12 inch 4/0 temco battery cables in parallel and series. I have an electronics box to that has a 1000 amp copper bus inside I have a far left positive cable 4/0 with gopower 400 amp ANL 7ft cable to bus from bank and far right negative connection 7ft 4/0 to bus . The 6kw 12kw msw inverter hardwire 50 amp port with 30 amp RV receptacle box 4 2ft 4/0 cables to bus and 3.5kw to 7.5kw puresine 2 4/0 cables 1ft to bus. 500 amp ANL fuse on positive side. 3 phase pull switch 6 awg x 3 Carol wire 60 ft from prototype wind turbine tower foldable telescoping tower .500 watt 3 phase wind turbine 5 blade and 3 blade .the switch handle is the 3x 6awg from turbine then 10 awg 3x carol 1 ft to 100 amp rectifier then to dump control board and solid state relay and a 300 watt 3 ohm resister bank. 2/0 4ft to bus bar and 4awg to dump 2 ft. 12v battery bank desulfinator and led lights inside with rocker switch.here is my YouTube channel showing the unit
https://youtu.be/OsLhXS_OvIU
https://youtu.be/vA6pi8aMUAM solar trackers
Night time wind turbine power input.
https://youtu.be/Ys_cP2cS7YI
Here is the inside of my solar controller box
https://youtu.be/EEjS9K-Q6B8
Here is an older video about the wind turbine tower I named it scorpion tower for patient.
https://youtu.be/S_AuPCd9rSM. I work on this all the time adding new stuff and upgrades and making changes or even redoing stuff better.let me know what you think.i am using this at home too I have an ATS and its saving some money on my Bill's too.
https://youtu.be/vA6pi8aMUAM solar trackersNight time wind turbine power input.
https://youtu.be/Ys_cP2cS7YIHere is the inside of my solar controller box
https://youtu.be/EEjS9K-Q6B8Here is an older video about the wind turbine tower I named it scorpion tower for patient.
https://youtu.be/S_AuPCd9rSM. I work on this all the time adding new stuff and upgrades and making changes or even redoing stuff better.let me know what you think.i am using this at home too I have an ATS and its saving some money on my Bill's too. Comments
I will make another video after I finish my upgrades. I have done allot since these videos the tracking system is about a week old its awesome. I ordered a wind speed sensor anemometer for it so the panels will park in high winds.
