Low Voltage disconnect
freddieoliveras
Registered Users Posts: 33 ✭✭
Hi, does anyone know a good affordable (less than $120) LVD ( Low Voltage disconnect) module?
It probably depends on the voltage and Amperage. I have cobbled some together from programmable voltage meters ($30) and higher amperage relays or contactors.
For 12 volts, Elk make a simple device for alarm panels.8 kW Enphase micros AC coupled to a SolArk 12K -
There are many in the under $20 range <100V. The real question is what do you want to disconnect. What they send a signal to can be expensive. What voltage and amps?
I need it for a 48V battery bank and want to activate a relay
A similar one is used by the DIY Electric Car crowd:
https://www.amazon.com/Programmable-Voltage-Current-Motorcycle-Automotive/dp/B0183D1DGU
freddieoliveras said:I need it for a 48V battery bank and want to activate a relay
If so, charge controllers often include aux ports which can send a relay trigger signal (typically 12v) based on various conditions, including low voltage. The trigger is generally very low current, just enough to activate the relay coil. If charge controller or whatever aux output isn't available, there are lots of other pretty cheap ways of sending the trigger.
The load side of the relay has to be rated to disconnect the load current though, which is where it can get expensive. Contactors capable of disconnecting 48vdc safely and repeatedly at higher amperages can get spendy.Off-grid.
Actually I have an Outback FlexMax and a MATE, the MATE has AGS (automatic start generator) but I have been trying for a few months with Outback support to male it work, but brother we can’t make it work, so I’m looking for a second plan.
Some inverters also have a Low Battery CutOff but mine does not.
This one seen pretty nice
https://4thdsolar.com/products/battery-monitoring-system-thornwave
- 227 Forum & Website
- 618 Discussion Forums/Café
