panel wiring
ws9876
Solar Expert Posts: 453 ✭✭✭
For 1 panel ,12v charging 300 watt panel ,only putting out about 25-28 volts,,KID controller.... I have a 15 ft run from panel to jct box using 12 ga metal jacket romex,then I want to use available 14 ga romex for 25 ft to KID. Just for 1 panel.
Any reason I cant do that?
Is this your plan ?
300 Watt PV Panel <=> 15ft of 12 awg <=> J-Box <=> 25ft of 14 awg <=> KID Controller
Yes, it can be done.
Have you calculated the Voltage Drop? -
It isnt really an issue ...just a simple 12 v battery
I am just making use of a damaged panel...
