Help with solar panel voltage
DJJ
Registered Users Posts: 7 ✭✭
I have a 1200 W renogy array. 8 150 w at 12 v. with midnite classic 150 96 v charger and a aims 4000 w pure sine inverter.
I what add to my panel array. Will a renogy 300 w at 24 v panel work? Battery bank is 24 v
PS my aims 4000 w inverter is 24 v input
You generally want added panels to be within 10% or so Vmp, so (eg) if your 12v nominal panels are 18Vmp in strings of 2 for ~36v, adding panels with a Vmp around 33-40v should work. If the new panel is more like 30Vmp, it isn't likely to work well.Off-grid.
Hey Thanks That is helpful
- 234 Forum & Website
