solar inverter??
ml2482
Registered Users Posts: 2 ✭
I've noticed some DIY kits can produce X Watts but the solar inverter is rated below the production amount. Take the example below. Total panels can produce 5760 Watts but the kit comes with a 5000 Watt inverter. Is the inverter sized correctly?
Grid-Tie Solar Power Kit with 5760 Watts of Panels and 5000 Watt SolarEdge HD-Wave Inverter
In general, solar panels produce less power (Power = Volts * Current) than their nameplate rating. As the panels get hot (not freezing weather, full sun on panel), the Vmp (voltage maximum power) drops, and so does the available power.
And most MPPT based (maximum power point tracking) hardware (solar charge controllers, Grid Tied inverters) are based on buck mode switching power supply designs. These types of power supplies have the ability to limit their maximum power/current throughput to their rated power--So "over paneling" does not hurt or damage these devices.
Typical over rating is around 1/0.77 to 1/0.75
We assume that in most conditions, the solar panels will output around 75% to 77% of their rated power a few days/times a year and, in general, very little of the available harvest is "thrown away".
For a 5,000 Watt GT inverter, we would suggest a maximum (cost effective) over rating of:- 5,000 Watt inverter * 1/0.77 panel+controller derating = 6,494 Watt array "cost effective" maximum
Of course, good ventilation and air circulation is a big help. The engineering rule of thumb is for every 10C/18F increase in temperature, there is a x1/2 reduction in life (and conversely, every drop of 10C/18F is a 2x increase in aging life).
Thanks for the info Bill
