Schneider Electric Conext Insight 2 Availability
neutronspin
Registered Users Posts: 51 ✭✭
I am currently running Schneider Conext Insight software for my system. Does anyone know how I can download or get Insight 2 for my system? I have a ComBox on the system. Do I need the Gateway to run the application? I think it is cloud based. I think for my Insight it just was a simple download and install on my PC. I can't seem to find it on the Schneider website. Any help appreciated. Thank you.
here is a link that I wrote about. You do need the gateway for CI2. Itis on the Schneider site under monitoring.
https://forum.solar-electric.com/discussion/353921/new-inverter-xw-pro-new-conext-gateway-with-easy-remote-monitoring-on-conext-insight-2
Dave Angelini said:here is a link that I wrote about. You do need the gateway for CI2. Itis on the Schneider site under monitoring.
https://forum.solar-electric.com/discussion/353921/new-inverter-xw-pro-new-conext-gateway-with-easy-remote-monitoring-on-conext-insight-2Thanks Dave....It must be a newer addition to the Conext line. Does it have a practical use for smaller systems?....I suppose it is a step up from the ComBox. I will check out the link.Now if only I could have Alexa report the data....in the future?.....
