Will these solar panel be too much for a 100A Charge Controller?
hmong2017
Registered Users Posts: 39 ✭✭
12 solar panels
GCL SOLAR Model GCL-P6/72335
Max power 335W
Max Power Voltage 38V
Max Power Current 8.82A
Charge Controller is
Renogy Rover Li 100A Amp MPPT Solar Charge Controller
Should I remove two solar panels?
Just continue the conversation in your other thread... It usually keeps things more focused on your questions if you have one thread vs asking the same/similar questions in multiple threads.
