Inverter shuts down system
ssmith1952
Registered Users Posts: 25 ✭✭
- HELP I have set up two 100 watt solar panels in parallel, running into a 30 watt control box using one 12 v deep cel sealed battery with attached 1100 watt inverter. everything charges well. Battery at 100% and about 13.5 volts when I turn on the inverter the whole system shuts down. What’s happening here?
- in ssmith1952: AC inverter shuts solar system down Comment by ssmith1952 April 13
I have moved your question to its own thread:
https://forum.solar-electric.com/discussion/comment/397219#Comment_397219
Continue the discussion over there (you already have some replies).
- 234 Forum & Website
