NEC Definitions
Anybody know how the 2017 NEC defines ground-mounted systems? My understanding is that it's considered a structure and not a building. But I'm not finding much on it.
I'm trying to determine the need for raceway labels, (690.31(G) is what I'm referencing). I don't have the code but from what it sounds like; raceway labels apply to all PV System DC circuits on or in a building. But if there is a distinction by the NEC between a "structure" and a "building", and a ground-mounted system is a "structure", like a solar farm for example, then raceway doesn't require labeling.
The labeling I'm referencing reads :"WARNING: PHOTOVOLTAIC POWER SOURCE".
Any clarification is greatly appreciated!!
A ground mount is a "structure" way looser code set than a "building" which is meant to be "occupied", not sure on the labeling though! The warning label you mention is required on a building so that firefighters know to look for the solar shut down system. There are also special labeling if a building has more than one power source , not normally allowed but not uncommon in industry to have both 480 and 240 in legacy systems, new construction it's not allowed. Same reasoning. Safety for first responders. Signs at all power sources. If your solar shutoff is not next to the main panel you will probably have to label every power source to the building.
2 Classic 150, 2 Kid, 5 arrays 7.5 kw total 2ea. 2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200, 2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100, 2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4,
- 230 Forum & Website
