Draw power simultaneously via AC and DC
Matty
Registered Users Posts: 36 ✭✭
If an inverter is connected to an AGM battery, is there any issue with drawing AC power from the battery via the inverter and simultaneously drawing DC power via an adapter connected directly to the battery’s terminals?
I do it all the time. 48 to 12vdc converter to run fans, chargers, tracker actuator motor. Just don't want to forget to calculate how many amp hours are being drawn down by the dc loads (if that's important to you).
