Solar powered boats
With lead acid, you wouldn't likely get to 100% in 30 mins. The last 15% or so to full is less efficient and slower than at lower states of charge. You can force it to a degree with higher charging voltage, but it's hard on the battery.Off-grid.
1000w x 4 x 1/6hr ÷48v = ~14ah.Off-grid.
- 626 Discussion Forums/Café
