Pwm or Mppt controller for this setup
706jim
Solar Expert Posts: 529 ✭✭✭✭
I have an old set of panels facing south (about 400 watts) and three 320 watt panels facing west. These are regulated by an old Trace C40 Pwm controller. I'd like to replace the older panels with another three 320 watt panels and if possible keep the same charge controller. Is there any benefit of going with a newer Mppt controller if the panel orientation stays the same, with the southern panels losing sun as the western panels start gaining it? With all of the existing panels facing in the same direction I would see about 42 amps of current. With the two sets separated as described, the old set generates about 8 amps and the newer (western facing) group generates about 30 amps. The reason I ask is that the two groups of panels will never be facing the same direction due to available space to mount them. The C40 is limited to at most 40 amps at the 24 volts I'm running.
Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
Depending on the panel specs (esp. Vmp) and local climate, you might get a bit better harvest with MPPT(s). IMHO the existing controller would probably work ok though.Off-grid.
Another factor might be wiring, if the existing 400w wiring is marginal or too light for the new panels.Off-grid.
