panel wiring
wwctv3
Registered Users Posts: 2 ✭
need instructions
diagram / sketch
how to wire 8 panels
side by side ( not ) end to end
24 vdc system
need 75.2 vdc
in put at the charge controller
Panel electrical data:
240w ea.
voc - 37.6
Isc - 8.22
please reply
diagram / sketch
24 vdc system
need 75.2 vdc
240w ea.
voc - 37.6
Isc - 8.22
please reply
You would wire as 4 strings of 2 panels each. Each string of 2 would be wired by connecting the +ve wire of one panel to the - ve of the other, leaving 1 +ve and 1 -ve per pair. The +ve from each pair would go to a breaker or fuse in a combiner box, then to a common +ive bussbar. The -ve from each pair goes straight to a -ve buss.
A single +/- pair goes from the combiner to the controller via a breaker sized for the larger wire.Off-grid.
Someone said to put all in series and parallel at the combiner.
i dont see how that can work --- 8 panels x 37.6 VDC will make 300 VDC
i need 75.2 input at the Chg,
Controller it will have to be series parallel.
i guess it dont make a d-m as long as i get he results i want.
Does anyone know of a pitcher of this on line
8 panels wired side by side so that --- 75.2 volts are input to the
chg, controller.
Thansk
One of the more confusing issues with solar is matching your panels into a "useful" solar array for your charge controller.
PWM (Pulse Width Modulated) controllers (less expensive type) need around Vmp-array~18 volts for a 12 volt battery bank, Vmp-array~36 volts for a 24 volt battery bank, and Vmp-array~72 volts for a 48 volt battery bank.
Too low of Vmp-array, and your battery bank won't charge. Too high of Vmp-array, your wasting a lot of energy from the array (Vmp-array~36 volts into 12 volt battery bank, about 1/2 of the array Wattage is wasted).
For smaller systems, PWM with smaller panels can be a good fit (less than ~400 Watt array).
For larger system, MPPT controller (Maximum power point tracking--More expensive, tend to be more fancy) use a switching power supply to efficiently "down convert" from Varray higher voltage/lower current down to Vbatt lower voltage/higher current (upwards of 95% efficient).
MPPT generally is more cost effective and better to design with for larger systems (typically 800 Watt or larger array). For "typical" (not cheap) MPPT type charge controller, A Vmp-array voltage of ~24 volts to 100 volts Vmp-array works just fine for charging a 12 volt battery bank...
So, if you need 75.2 volts for the Vpanel input for your charge controller (guessing Vmp-array ~ 75.2 volts), typically that would be 2x Vmp 37.6 volt panels in series, and then make 4x series strings, and connect those in parallel for a 2s x 4p array.
For safety, you should put a ~15-20 amp fuse/breaker (see panel specifications for series protection/fuse) in the positive lead for each array... The output of the "Combiner" circuit goes to a single positive bus bar (and all the negative are connected to their negative bus bar). And run that pair of heavy cables back to the charge controller/battery shed.
Vmp-array of ~75.2 volts sounds like a PWM controller charging a 48 VDC battery bank. Should work OK, but there are more design issues that need to be decided (how far is the wire run from Solar Array to charge controller--Long wire runs means thicker copper cable$).
This webpage does a good job of showing how all that Series/Parallel solar array connections are made:
https://pveducation.com/solar-concepts/series-and-parallel-wiring/
https://higher-octave.com/wire-solar-panels-parallel-series/ (more details on combiner box)
The first solar power system you will make--There are lots of issue that need to be addressed. And you will be doing a lot of learning.
If you are familiar with AC wiring in your home or even DC wiring in a boat/car--All good experience. If you are not familiar with electricity and the math+physical construction--Be very careful. Electrical not done correctly, can be a costly or even dangerous mistake.
I suggest that we start with Paper Design(s) and then, start looking for equipment that will support those designs (costs, availability, what meets your price/performance needs).
To get an idea of what a smaller do it yourself solar power system entails... 2ManyToyz has a lot of photos and comments. Go about 1/2 way down his page:
http://2manytoyz.com/
